Fluid Capacites!
merlin5577
Taunton, MA
2007 Cadillac Escalade 6.2L AWD
Engine, with filter..........6.1 quarts
Cooling System, Initial Fill..........17.7 quarts
Automatic Transmission, Total Fill
6 speed 6L80..........12.4 quarts
Automatic Transmission, 6L80 ReFill..........6.1 quarts
Differential, Front..........3 pints
Differential, Rear..........4.3 pints
Transfer Case, NVG 246-NP8..........4.1 pints
:cheers:
davbell22602
Stihl Chainsaw Man
Bunker Hill, WV
1990 Chevy C2500 2wd w/sm465 trany, 5.7L, 3.73 ratio semi float 9.5 14 bolt.
1977 jaguar xjs v12 5.3L w/ gm trany,
td 340 international dozer. need oil capicity.
merlin5577
Taunton, MA
Sorry guys i've been wicked busy. Havent been able to get over here much.
:cheers:
1990 Chevrolet C2500 5.7L
Engine, with filter..........5.1 quarts
Cooling System, With AC Initial Fill..........18 quarts
Cooling System, Without AC Initial Fill..........17.5 quarts
Automatic Transmission, THM400 ReFill..........4.4 quarts
Automatic Transmission, 4L60 ReFill..........5 quarts
3 speed THM400..........10.6 quarts
4 speed 4L60..........11.6 quarts
Manual Transmission, Muncie (5-SPD)..........4.1 pints
Manual Transmission, 4-SPD W/ TSIC..........8.5 pints
Manual Transmission, NV4500 ..........8.1 pints
Differential, With 10.5 RingGear Dana Rear..........7.2 pints
Differential, With 10.5 RingGear EX D Rear..........7.2 pints
Differential, With 12.25 RingGear Rear..........14 pints
Differential, With 8.5, 8.6 RingGear Rear..........4.3 pints
Differential, With 9.5 RingGear Rear..........5.5 pints
Differential, With 9.75 RingGear Rear..........5.5 pints
1977 Jaguar XJS 5.3L
Engine, with filter..........8.7 quarts
Cooling System, Initial Fill..........N/A
Automatic Transmission, TH400 ReFill..........5 quarts
3 speed TH400..........19.1 quarts
Differential, Rear..........3.2 pints
I'd need the year of the International to tell you the oil capacity.
:cheers:
davbell22602
Stihl Chainsaw Man
Bunker Hill, WV
:cheers:
:cheers:
I dont what year it is. All I know its old and has diesel engine and radiator. I'm guessing from what someone said and thats 1960's. I have pics of in the classifieds. Thanks for the other two though. On the chevy truck is that for the manual 4 speed with low capicity?
merlin5577
Taunton, MA
I cant go back to the 60's stuff to look it up, sorry. :( I will do some digging though and see if I can come up with that engine. :cheers:
On the truck, those are the only manual transmissions I can find info for so i'm guessing its the sm465.
