Fluid Capacites!
merlin5577
Taunton, MA
If anyone wants or needs the fluid capacities for their truck(s), just post up the year, make, model, etc... and I can get it for you. The more info you post the more I can get for you.
I can only go back to 1973, so if its older then that. My appoligies.
:cheers:
Cool!
For starters:
2007 GMC Sierra (GMT900) 4.8 AT 2WD
1999 Chevrolet Suburban 1500 2WD 5.7 AT LT
Cool.
2001 GMT800 Tahoe 4X4 w/ 5.3
2008 GMT900 Tahoe 4X4 w/ 5.3
dietz4ibanez
Willow Spring, NC
2007 Chevy Silverado 6.6l Duramax LMM
1999 Chevy Silverado K1500 350 5.7L - I am sure those will be the same capacities for the 98.
Brian, don't forget the 'Nox.
dietz4ibanez
Willow Spring, NC
I was going to ask but thought he was just checkin for trucks..
I guess it wouldnt hurt...
2010 Chevy Equinox v6 3.0 DOHC VVT W/6speed tranny
Might as well put the dump truck in here...
1999 Chevy Silverado 3500HD 6.5L Turbo Diesel of which I am guessing 4L80E...
Robert... you might be a busy beaver with this thread.
merlin5577
Taunton, MA
Cool!
For starters:
Sierra;
Engine, with filter..........6.0 quarts
Cooling System, GMT900 W/ AT W/ Elect Fan Initial Fill..........17.0 quarts
Automatic Transmission, 4L60-E ReFill..........5.0 quarts
Automatic Transmission, 4L70-E ReFill..........5.0 quarts
Automatic Transmission, Total Fill
4 speed 4L70-E..........11.0 quarts
4 speed 4L60-E..........11.0 quarts
Differential, with 8.25 ring gear Front..........3.0 pints
Differential, with 9.25 ring gear Front..........3.7 pints
Differential, with 8.6 ring gear Rear..........4.2 pints
Differential, with 9.50 ring gear Rear..........5.5 pints
Transfer Case,RPO NP2..........4.0 pints
Transfer Case,RPO NQG..........3.2 pints
Suburban;
Engine, with filter..........5.0 quarts
Cooling System, with AC Initial Fill..........20.0 quarts
Cooling System, W/O AC Initial Fill..........17.0 quarts
Automatic Transmission, 4L80-E ReFill..........7.7 quarts
4 speed 4L80-E..........14.0 quarts
Differential, Front..........3.6 pints
Differential, with 10.5 ring gear Dana Rear..........5.5 pints
Differential, with 10.5 ring gear EX Dana Rear..........6.3 pints
Differential, with 11 ring gear Dana Rear..........8.4 pints
Differential, with 8.5, 8-5/8 ring gear Rear..........4.2 pints
Differential, with 9.5 ring gear Rear..........5.5 pints
Differential, with 9.75 ring gear Rear..........5.5 pints
Transfer Case,NP241/243..........4.4 pints
Transfer Case,NVG 149..........4.9 pints
Transfer Case,NVG 236/246..........4.0 pints
Transfer Case,NVG 261/263..........4.0 pints
Very cool! Thanks.
merlin5577
Taunton, MA
Cool.
2001;
Cooling System, Initial Fill..........15.0 quarts
Differential, 10.5 EX Dana Rear..........5.5 pints
Differential, with 11.50 ring gear Rear..........7.6 pints
Transfer Case,NVG 236, 246..........4.0 pints
Transfer Case,NVG 261, 263..........4.0 pints
2008;
Cooling System, Initial Fill..........18.0 quarts
Automatic Transmission, 4L65-E ReFill..........5.0 quarts
4 speed 4L65-E..........11.0 quarts
Differential, Front..........3.0 pints
Differential, Rear..........4.3 pints
Transfer Case,BW 4485-NR3..........3.0 pints
Transfer Case,MP 3023/24..........3.2 pints
77eltigre
