Fluid Capacites!
merlin5577
Taunton, MA
When is that 2010 Nox going to show up? I already found out that it takes 6 qts of oil!
Sorry bud, I totally forgot, my mistake.
2010 Chevrolet Equinox 3.0L
Engine, with filter..........6.1 quarts
Cooling System, Initial Fill..........10.8 quarts
Automatic Transmission, 6T70 ReFill..........6.4 quarts
Automatic Transmission, Total Fill
6 speed 6T70..........9.6 quarts
Differential, Rear..........1.1 pints
Transfer Case, GETRAG 760..........2.2 pints
:cheers:
merlin5577
Taunton, MA
Looking for 03 sierra 8 cyl. 4wd ext cab..thanks bud..
2003 GMC Sierra 5.3L 4X4
Cooling System, With AT Initial Fill..........13.5 quarts
Cooling System, With AT & Optional REAR AC Initial Fill..........14.9 quarts
Automatic Transmission, 4L60-E ReFill..........5 quarts
Automatic Transmission, 4L80-E ReFill..........7.8 quarts
4 speed 4L80-E..........13.6 quarts
4 speed 4L60-E..........11.3 quarts
Manual Transmission, NV3500..........4.3 pints
Manual Transmission, NV4500..........8.1 pints
Differential, Front..........3.6 pints
Differential, American 10.5 R Rear..........5.5 pints
Differential, American 8.5 RingGear Rear..........4.3 pints
Differential, American 8.6 RingGear Rear..........4.3 pints
Differential, With 11.5 RingGear Rear..........7.7 pints
Differential, With 9.5 RingGear Amer Rear..........5.5 pints
Differential, With 9.75 RingGear Rear..........6 pints
Transfer Case, NVG 149..........4.5 pints
Transfer Case, NVG 236/246..........4.1 pints
Transfer Case, NVG 261/263..........4.1 pints
Wow, Robert. ON THE BALL with responses tonight. That was fast! :cheers:
merlin5577
Taunton, MA
1995.5 Toyota Tacoma 2.7L 4x4
Also 2008 Chevy Silverado 4.8L 4x4
1995 Toyota Tacoma 2.7L 4X4
Engine, 4WD, with filter..........5.3 quarts
Cooling System, Initial Fill..........9 quarts
Automatic Transmission, A340E ReFill..........1.7 quarts
Automatic Transmission, A340F ReFill..........2.2 quarts
Automatic Transmission, A43D ReFill..........2.6 quarts
4 speed A43D..........6.9 quarts
4 speed A340E..........7.7 quarts
4 speed A340F..........10.4 quarts
Manual Transmission, ..........5.3 pints
Differential, With ADRD Front..........2.6 pints
Differential, Without ADRD Front..........2.4 pints
Differential, 2WD Without CS Rear..........6 pints
Differential, 4WD Extra Long Rear..........4.5 pints
Differential, With LSD Rear..........5.5 pints
Differential, Without LSD Rear..........6 pints
Transfer Case, ..........2.2 pints
2008 Chevrolet Silverado 4.8L 4x4
Cooling System, Initial Fill..........16.9 quarts
Automatic Transmission, 4L70-E ReFill..........5 quarts
4 speed 4L70-E..........11.3 quarts
Differential, With 8.25 RingGear Front..........3 pints
Differential, With 9.25 RingGear Front..........3.6 pints
Differential, With 8.6 RingGear Rear..........4.3 pints
Differential, With 9.50 RingGear Rear..........5.5 pints
Transfer Case, BW 4485-NR3..........3 pints
Transfer Case, MP1222/1225..........3.2 pints
Transfer Case, MP1226..........3.2 pints
Transfer Case, MP 1625/1626..........3.2 pints
Transfer Case, MP 3023/3024..........3.2 pints
:cheers:
merlin5577
Taunton, MA
2001 Suburban 2wd with 5.3 , 3.73 ring gears, w/aux trans cooler and rear AC
1997 Blazer 4.3 4x4 auto trans
2005 Altima 2.5s auto trans
2001 Chevrolet Suburban 5.3L
Cooling System, With FR & RR AC Initial Fill..........15.9 quarts
Cooling System, With Front AC ONLY Initial Fill..........14.3 quarts
Differential, Dana 11 RingGear Rear..........5.5 pints
Differential, With 9.5 RingGear Rear..........5.5 pints
Differential, With 9.75 RingGear Rear..........5.5 pints
1997 Chevrolet S SERIES BLAZER 4.3L 4X4
Engine, with filter..........4.6 quarts
Cooling System, Initial Fill..........12.2 quarts
Manual Transmission, NV1500..........5.8 pints
Differential, With 7.25 RingGear Front..........2.6 pints
Differential, With 8.25 RingGear Front..........4.3 pints
Differential, With 7.5 RingGear Rear..........4.1 pints
Differential, With 7.625 RingGear Rear..........3.6 pints
Differential, With 8.6 RingGear Rear..........4.1 pints
Transfer Case, NP207..........4.7 pints
Transfer Case, BW4472..........3 pints
Transfer Case, NP231, NP233..........2.2 pints
Transfer Case, NV233..........2.2 pints
2005 Nissa Altima 2.5L
Engine, with filter..........4.5 quarts
Cooling System, Initial Fill..........8.1 quarts
Automatic Transmission, 4 Speed ReFill..........4.9 quarts
Automatic Transmission, 5 Speed ReFill..........3.9 quarts
4 Speed..........9.8 quarts
5 Speed..........7.8 quarts
Manual Transmission 5&6 Speed, ..........4.7 pints
:cheers:
2005.5 VW Jetta 2.5?
Maybe the 2006 would be easier.
merlin5577
Taunton, MA
2005 Volkswagen Jetta 2.5L
Engine, with filter..........6.4 quarts
Cooling System, Initial Fill..........10.1 quarts
Automatic Transmission, 09G ReFill..........3.7 quarts
6 speed 09G..........7.4 quarts
Manual Transmission, 02J..........4.3 pints
Manual Transmission, 02M..........4.9 pints
Differential, Front..........1.5 pints
