Fluid Capacites!
The_Chupacabra
Wichita, KS
Engine, with filter..........4.5 quarts [1]
Cooling System, Initial Fill..........13.2 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 4L60-E Initial Fill..........5 quarts
Automatic Transmission, 4L80-E Initial Fill..........7.7 quarts
Automatic Transmission, Total Fill
4 speed 4L60-E..........11.2 quarts
4 speed 4L80-E..........13.5 quarts
Manual Transmission, NV3500/M50..........4.2 pints [2]
Manual Transmission, NV3500/MG5..........4.2 pints [2]
Differential, Front..........3.6 pints
Differential, 10.5 RingGear Rear..........6.3 pints
Differential, 11 RingGear Rear..........8.5 pints
Differential, 8.5 RingGear Rear..........4.2 pints
Differential, 8.6 RingGear Rear..........4.2 pints
Differential, 9.5 RingGear Rear..........5.5 pints
Transfer Case, BW4470..........3.2 pints
Transfer Case, NV241/NV243..........4.4 pints
Transfer Case, NV236/NV246..........4 pints
Transfer Case, BW4401..........3.2 pints
jillocity
fluid capacities for 1990 v1500 suburban
i want to change the oil, need to know how many quarts of oil to buy :) thanks
This is listed for the 1990 Sub 1500 with the 5.7l engine.
CAPACITIES:
Engine, with filter..........5 quarts [1]
Cooling System, With AC Initial Fill..........20.1 quarts
Cooling System, Without AC Initial Fill..........17.4 quarts
Automatic Transmission, 4L60 Initial Fill..........5 quarts
Automatic Transmission, THM400 Initial Fill..........4.3 quarts
4 speed 4L60..........11.5 quarts
3 speed THM400..........10.6 quarts
Differential, With 10.5 RingGear Dana Rear..........5.5 pints
Differential, With 10.5 RingGear Rear..........7.2 pints
Differential, With 12.25 RingGear Rear..........13.9 pints
Differential, With 8.5 RingGear Rear..........4.2 pints
Differential, With 9.5 RingGear Rear..........5.5 pints
Differential, With 9.75 RingGear Rear..........5.5 pints
Differential, Front..........4 pints
Transfer Case, BW1370, BW4401..........3.2 pints [2]
[1] After refill check oil level.
[2] Identification: check tag on case.
jillocity
sorry for late reply
thanks for the info...it will help a lot...i've been on a the road a lot, so hadn't been to truckmod for a month! now i'm off again...will return :D
