mblouir
I need a hobby.
Sorry that these didn't turn out so well---it's really sunny out so I tried to balance the lighting as much as I could while holding wire.
Just now went and marked the wire where I want to cut it. Have a little leftover so I'll give each measurement a few more inches. Going to edit these following pictures for the How-To, but it at least gives an idea of what I'll be doing.
Will actually be doing the Big 4, but I need to order two more ring terminals:
Now, the last one isn't necessary but it sure as heck doesn't hurt and I have the extra wire for it. It essentially improves the ground connection between the frame and chassis.
Will be using my wire cup brush drill attachment to clean contact points.
The orange/black cable can be seen running between (+) and alternator. Thick (-) wire can also be seen running down and out of sight towards front of engine bay to frame:
(-) to chassis upgrade here:
(-) to frame running down and out of sight here:
Found it! (-) to frame comes over here to lowest bolt seen:
Laying out my cable and marking:
Using this bolt for engine ground:
- Battery (+) to Alternator
- Battery (-) to Engine Ground
- Battery (-) to Frame
- Battery (-) to Chassis
