Ross.....go big or go home!
Carl, we really don't have a lot of room--just enough to squeeze by. People have slowly figured out how best to fit audio stuff in F150s.
On to some more pics. I went ahead and put wire loom on the power wires running under the truck. Better safe than sorry. Also had to relocate the amp for my components because it was in the way of reinstalling the seats. A small metal bracket couldn't get into place. So I pretty much switched up the amp locations.
Also reinstalled the rear seats. Zip-tied a little clip so it's not so hard to take them off next time. Should only have to pop off the back section and install the subwoofer amp when it gets in.
The sub box doesn't go back as far as I would like it to, but that's my fault. When I put my deadening in I also put in 1/4" carpeting from Lowe's (to help with road noise). That adds quite a bit of thickness to the contours of my floorboard, so when I try to push it back all the way it just won't go. It's not too bad, though. Plenty of foot space---even I crawled back there and I'm 6'5".
Anyways, on to the pics...
Wire loom on power wires:
Starting to install seats. Clip on left (zip-tied) couldn't go in place because of amp:
Torx bolt locations (I think T50--not 100%). For relative locations look at first pic of seats:
Clips that are a B**** to release when trying to get off upper half of back seats. Zip-tied for easy removal next time:
For metal bar with brackets and lower rear seats, four bolts are used to hold in place. Far left one is a long bolt---other three are nuts that go on built-in bolts coming out of floorboard. Here's the left bolt. It's also a B**** the first time you take it out due to the loc tite:
Amp relocated, seats back in place, sub box almost pushed back all the way. Managed to get it back a little bit more:
Upper rear seat. Be careful with metal spokes in 2nd pic. Clips in 3rd pic go in top three holes on back wall. 4th pic shows the little hole you have to hit when you poke a screwdriver in there. I'll take more pics when I pull it back off:
Almost finished:
Scooted back all the way--would like more but nothing I can do:
Went to grab some Dominos in case of power failure tonight (expecting heavy ice). Can say one thing that I learned today:
The dog loves having "her" seats back.
