Tyler's KZ1000 Rebuild Thread
tleach17
I wanna be your Maine Man
Central Maine
Im not sure. I have not pulled the cover off yet. I was going to check the gap and look for burnt points. Could they cause a problem with the coils?
Kennyray
Ossian, IN
It's been a long time, but if I remember correctly, the points control the firing of the coils. You have 2 coils, correct? If so you have 2 sets of points. Thats the way my CB750 was set up.
tleach17
Central Maine
I am clear on that. I know the coils are bad. I am trying to figure out what made them both fail so that i dont burn up the new set.
tleach17
Central Maine
The points close the circuit to complete the spark but the igniter is what sends the high voltage to acheive spark if I remember correctly.
After you check over the basics and before you start buying expensive shit or taking everything else apart, free it up, lightly oil the cylinders, turn it over a few turns, feed it a small amount of gas and try to start it. The carbs are going to need a rebuild most likely, but you'll know if the ignition system is operational.
tleach17
Central Maine
Thanks JIM. I put a little seafoam in the cylinders today to remove the moisture. I was going to put a little marvel mystery oil in the cylinders and turn it over with the rear wheel since I dont have a kick starter. Do you think the marvel with effect the clutch?
Won't hurt a thing.
I'd change the crankcase oil before starting it though. Pretty easy on those bikes.
