Project Battle Notch
LMSeven
Μολών λαβέ
Across the Neighbors
Probably glass it
The new core support. Metal brakes are awesome
Factory K member out
Discovered it has a 4.10 or 4.11 gear. The upper/lower control arms are after market. I will have to see how they do, if they suck I'll get adjustable UPRs.
This is the outside frame by the strut tower. The spring perch mounts right below it. IIRC. I was hung over all damn day.
Going back tomorrow. Probably tie in some new metal around the base of the strut towers and put in the K member.
That sucks. Is it yours?
LMSeven
Μολών λαβέ
Hit it for a little bit today.
This pic does no justice for my awesome welding skillz. I think it will take 1 more day to finish the towers and then the K member will go in. I'm siked we are done taking stuff off the car and instead putting stuff on.
The 4.10 gear is going be a problem. The radials I have now will not fit without trimming, and the old timer really seems to be against it. I can't do that myself so it seems to be out of the question. 28" tires with a 6700rpm redline would max out at 136. Tis going to need gear.
CJ Hungus
Moderator
Ham Lake, MN
Go 3.23 or 3.08 :thumbs:
LMSeven
Μολών λαβέ
That will probably be the absolute last thing to be done. He's not much for the performance stuff, and thinks I don't know what I'm talking about..
So the 1st time it goes down the track and redlines at 1000' it will get a new gear and give a long awaited "I told you so" :lol:
