I got an answer about A2W with a Whipple.
Back on the topic of getting or not getting the S/C, I asked if the rotors were loose and the seller said they are solid and appears the unit has been rebuilt recently.
Looks more and more like I might be going for it!!!!
air to air intercoolers won't work with a whipple because the way its designed with the TB on the intake side of the compressor, every bit of volume that you add after the compressor will reduce the efficiency and boost of the blower, with an air to air you have SO much post blower volume that it would virtually make the blower worthless, with the air to water, you only have a small amout of added volume, and even with that small amount, people were seeing ~1-2psi boost loss, and when you're only running 6-8psi, thats a decent amount. think what it would be with all that air to air piping.
