nubuilder got a Whipple - SEE POST #33
buRRp
Supporting Member
Staff member
Supporting Member
Very nice. Hope you can find a the stuff you need for it. :fingersx:
Looks good Matt. Hope you can get it all pieced together. :thumbs:
Thanks. :) I hope so too. :uhoh:
I'd email the guy you got it from and ask him :wtf?:, where are all the pieces/parts. :dunno:
I am going to, but I can't be too angry with the seller. They did say that some stuff was missing (if I remember right), but this is more than just some. I'm waiting on a copy of the manual from another member. He said there's a parts list in it (or at least I hope). Once I get that, I'm gonna make a check-list and go through what I've got. After that, I'm calling Whipple.
Yeah, so far I'm missing an idler pulley (which shouldn't be that hard to match its size), but I'm also missing the bypass/blow-off valve (whatever you want to call it). I have half of it, but I'm pretty sure I don't have the valve half, just the other connecting side of it (if that makes any sense).
Alright, I read over the manual quick and highlighted a bunch of stuff. This is straight from the manual.
-4 aluminum spacers (2-black). Locate the 2 black spacers that are 5/16" thick with a 3/8" hole
-a piece of 1 5/8" diameter split loom cover
-two most outside hex head bolts (10x100mm) and washers
-two round aluminum spacers (3/8" hole and 3/8" thick)
-remaining 10x100mm bolts and washers
-two 3/8-16x1" long counter sunk torx head bolts
-10x30mm Allen bolt and washer
-two pre-assembled 3" diameter steel idler pulleys (I'm guessing these are the two pulleys; one of which I don't have)
-new accessory/supercharger drive belt (KO61115). Use belt KO61120 on engines with large-case alternator
-6x45mm stud, nut & washer (this is for mounting the throttle body)
-two 6x30mm Allen bolts and washers (this is for mounting the throttle body)
-3 3/8" diameter, 2 1/2" long piece of orange silicone hose
-two #52 clamps
-6mm Allen bolts (two 6x30mm and one 6x65mm) and washers
-IAT extension cord (I may or may not have this; I'll check)
-3 1/2" diameter hose
-#60 clamps (two I think)
There's mention of a "new bracket" for holding the throttle cable and cruise control cable. If there is suppose to be a new bracket, I don't have it and will have to find it also
At this point, I'm not really worried about finding anything except for the bypass valve (my number one concern), idler pulley, 2 5/8" pulley (for the main drive on the S/C), and the throttle cable bracket. I'm more concerned with the "hard parts" before the screws and bolts which I can probably easily find and order
Just quickly reading the manual, the driver's and passenger's valve covers will be switched around, the engine hoist bracket by the A/C compressor will be removed, and maybe a few other small things.
