Might not be able to pass on this.
CJ Hungus
Moderator
Ham Lake, MN
A single 5 inch exhaust is almost overkill for any diesel up until the 1000hp range so dual 5 inch with dual 7" tips is just for looks and it doesn't look good IMO.
dietz4ibanez
Willow Spring, NC
dietz4ibanez
Willow Spring, NC
Who cares what you don't like. :lol:
Does the tip look bad on my truck in your eyes?
CJ Hungus
Moderator
Ham Lake, MN
Wow. Maybe you should read up on that one. :lol:
And its not true dual. You can't pull that off unless you are running twins. The exhaust on my current truck is a 3" diamond eye dp that flows into a 4" section about 2 FT which emptys out into 5 inch. System that has option for duals around where the muffler used to be... I bought the 5" because I like the sound of it 100 times over the 4" and husker diesel was running a special on the 5" so that's what I got.....
What cracks me up the most is Mbrp highly recommends the 4-5" systems. Its going to be about the difference of adding/removing a tbs on a gas motor... :lol:
I want to run duals on this truck to do something different.
And honestly I don't think Mbrp even offers anything smaller than 4".?
So you're telling me that you need over a full 5 inch exhaust for say 800hp?
When someone says duals.... that means true duals.... anything else is just a single system splitting off into two exits. You did not specify that.
dietz4ibanez
Willow Spring, NC
Based on your comment I felt that you would know that mbrp only makes those kits one way. So generally I would understand the reason for specifying if I was saying duals on a gasser. :brain:
