Low4x4`s build - Updated often!
R
Riggs
maybe when i do the rear diff i will try and find a magnetic rear diff plug so next time i can just suck the old stuff out with a pump and put the new stuff in
1LOW4X4
Yeah I use a gasket with a little rtv....
Why not amsoil? Royal purple is effin expensive, and a few guys here have independent tests showing amsoils quality!
R
Riggs
i get it through a distributor where i work for cost, which is a lot less than me buying amsoil
1LOW4X4
4 bucks a quart for amsoil with the preferred customer number....you can get RP for less?
R
Riggs
its $5 a quart of 5w-30 Royal Purple, and i dont pay shipping or tax
and i get it next day
1LOW4X4
Either way, if you use synthetic oil in your diffs, you'll never need to change it again. I spent a year at Mobil Refinery here in town, and hung out with the operators there....Mobil 1 synthetic diff oil doesnt break down. At least not in the life of your vehicle. I'd expect nothing less from any other high quality synthetic gear oil
ANd make sure you dont have the t-case that only takes GM fluid
dietz4ibanez
Willow Spring, NC
Is your drain plug at the bottom of the differential cover?
Reason why I ask is because I suspect your differential cover is aftermarket...
My 99 when it had the 10 bolt did not have a drain plug. Neither does the 14 bolt that I put in it...
R
Riggs
i just checked it and its actually $6.62 a quart for 5w30 is what i pay, but its more convenient for me because it comes right to my work where the shop is heated to 60 degrees and i have a lift, and rags and place to put the old oil...
but both are great, i used to run amsoil in my 4 wheeler and it is great stuff
1LOW4X4
Just for you Brian....and yeah I have a leaky cover too lol. No gasket in there right now
