1LOW4X4
Im pretty certain that the axle seals are a common problem, and ive heard that they can leak after you replace them, which mine are doing, and has been doing since not long after I changed em. I'll probably do a write up on them when I do this set.
I've decided I'm not going with 17's. I'm instead going to lift the truck up the inch that I had dropped it, and buy taller tires for the 22's. That will get me in alignment, away from the driveshaft in the back, and give me more sidewall and better ride and more protection for the rims.
The truck actually sat lower with the 17's on it
