Well how about that !?!
Got lucky with the rebuild on the steering column ..
What I'm using is out of a 1975 Cadillac Coupe De Ville ( Cut down to fit )
It was a bit on the loose side being in use for 40+ years.
Needed a few parts to freshen it back up ..
Tried to find Nos pats but soon gave up that idea ..
Next thought was to grab up a junk column and hope that the parts that I'm needing are still serviceable ...
The years that would work super well was 71 to 76, in 77 they did a design change ..
That seem to turned into a hunt for Hitler's Gold Train .. !!
Did run up on a 77 year model ... Took a gamble on if the internal part would be interchangeable ??
Here's where the luck was at ..
The parts I needed was the same ..
The lower column bearing ... Mine had a crack in the plastic retainer ..
Tilt cast support, again with a crack ..
And a item that I deleted back when I installed the column .... The key buzzer contact switch ..
Seen no need for it back then, but since I'm deep into the make over I figured "What the Heck"
Soon to be back together and working like day one ... Yippee
Edit;
Well poo, couldn't use the key buzzer switch from the 77 column, not made the same as the 76 and back ..
On the hunt for a switch ..
