IH 54 R-100 4X4
Jesse S
Belleview Florida US of A
So when are you buying it :dunno: :D2
Just as soon as I hit the lottery .. !
Also will be buying a car that those boys are in the mist of building ..
This car is bad-ass as they come, it's a 53 Vette on a C8 chassis ...
They bought a brand new C8, peeled the body off of it and putting on custom made 53 Vette skin !
That's right a mid engine 53 Corvette ...
I'm taking another trip over there with my camera .. Real soon .. !!
Jesse S
Two knobs away from having all the parts ...
Gauges turned out looking good ...
Got them all to a close match to each other now ...
The convex lens sure did make a difference ..
Jesse S
Working the firewall is going well with the test fitting ...
A few needed holes was cut in for my needs of what going on now ..
Oh boy ... Can't wait to get into the wiring work ...
( Kind of looks like "Walt Disney" was eating spaghetti and upchucked ) Lol
I wouldn't know where to begin with all of that wire.
Jesse S
Well how about that !?!
Got lucky with the rebuild on the steering column ..
What I'm using is out of a 1975 Cadillac Coupe De Ville ( Cut down to fit )
It was a bit on the loose side being in use for 40+ years.
Needed a few parts to freshen it back up ..
Tried to find Nos pats but soon gave up that idea ..
Next thought was to grab up a junk column and hope that the parts that I'm needing are still serviceable ...
The years that would work super well was 71 to 76, in 77 they did a design change ..
That seem to turned into a hunt for Hitler's Gold Train .. !!
Did run up on a 77 year model ... Took a gamble on if the internal part would be interchangeable ??
Here's where the luck was at ..
The parts I needed was the same ..
The lower column bearing ... Mine had a crack in the plastic retainer ..
Tilt cast support, again with a crack ..
And a item that I deleted back when I installed the column .... The key buzzer contact switch ..
Seen no need for it back then, but since I'm deep into the make over I figured "What the Heck"
Soon to be back together and working like day one ... Yippee
Edit;
Well poo, couldn't use the key buzzer switch from the 77 column, not made the same as the 76 and back ..
On the hunt for a switch ..
Edit;
It seems as though life is full of glitches. Just when you think you're on a roll, something has to jump up and bite you in the ass.
Jesse S
Seems that the key buzzer switch is going to be hard item to find ..
Not having much luck on locating a new one ...
Back to the junkyards ....
That little part has the column on hold, had a full head of steam toward completing the assembly until I tried loading the 77 switch in the 75 column ...
That's when I started hearing music ...
