How Many of You Warm Up?
DarrenWS6
Wellsboro, PA
I always on cold starts, let my truck run until the rpm drops to the 800s, then get moving, cold days maybe 5 minutes to let the engine hit 100 degrees before working it.
matt3
I am lazy IS my custom title!!!
Illinois
I let it run at least long enough for the rpms to drop after start on the cold days...even on the warm ones
That's what I do, even in the summer. In the winter I might let it go an additional minute after the rpm's drop.
DV2000NJ
The Browmaster
Central NJ
I'm always late for things, so I let it warm up until the RPM start to move towards normal, then I pop it in drive, and idle down the driveway. I don't give it any gas until the piston slap shuts up. :lol:
Once the 6.0 goes in, that thing will be treated a bit better in cold weather, hopefully I'll have a remote start by then.
Here is something I dug up on excessive idling.
#2 is what I've always heard.
Myth #1 The engine should be warmed up before driving.
Reality True, the engine must be warmed up, but idling is not an effective way to warm up your vehicle, even in cold weather. The best way to do this is by driving the vehicle. With today's modern engines, and the advent of electronic engines, you need no more than about 30 seconds of idling before driving away, even on the coldest winter days.
Myth #2 Idling is good for your engine.
Reality Excessive idling can actually damage your engine components, including cylinders, spark plugs, and exhaust systems. An idling engine is not operating at its peak temperature, which means that fuel does not undergo complete combustion. This leaves fuel residue that can condense on cylinder walls, where they can contaminate the oil and damage parts of the engine. For example, fuel residues are often deposited on spark plugs. As you spend more time idling, the average temperature of the spark plug drops. This makes the plug get dirty more quickly, which increases fuel consumption by four to five percent. Excessive idling also lets water condense in the vehicle's exhaust, leading to corrosion and can reduce the life of the exhaust system.
Myth #3 Shutting off and restarting your vehicle is hard on the engine.
Reality Frequently restarting has little impact on engine components like the battery and the starter motor. Component wear caused by restarting the engine is estimated to add $10 per year to the cost of driving, money likely to be saved many times over due to fuel savings.
Myth #4 Shutting off and restarting your vehicle uses more gas than if you leave it running.
Reality The bottom line is that over 10 seconds of idling uses more fuel than restarting the engine. As a rule of thumb, if you are going to stop for 10 seconds or more - except in traffic - turn off the engine. You'll save money, and you won't produce harmful Carbon Dioxide, the leading greenhouse gas.
M.Cueva
jrrod2004
Austin, Texas
huh, I warm it up just enough to get some heat and then take off...she never drives quite right when she is running cold...
If I can see, it only gets a couple minutes... Otherwise, I wait until I can see, lol.
At colder than -25, I'll let it sit until the temp needle starts moving... But only because the transmission doesn't shift smoothly unless it's warmed up :lol:
Stumpuller6.5
Shits gonna get Abrasive...
Canukian Land
myth number 2. For example waukesha industrial engines will NOT warranty and engine that is being operated at less than 50% rated output. It causes exccesive oil to get pulled through the intake valves (due to the higher intake vacuum) which will cause premature failure of the cylinder head and possibly the cylinder.
So esentially its best for your engine to drive with the pedal on the floor. :lol:
C
Cashezo
I'm usually rushing in the morning, so I just remote start it and a minute later I take off. Ticks like a bitch, though.
