Z71 Kris
Independence...
ddm doesn't have them listed, I live in the city I am thinking 35 wt will be enough, and I like the bright white color, so I will prolly get the 5k 35wt, but I dont see the 9145 listed pish posh..
i think 35w should be enough either way. as long as you have them aimed right.
I dont see my fogs listed, any body gots an idea?
Fog/Driving light
9145
Same as Fords!![]()
You mean they don't make GM-specific lights?!
I dont know barely any manufacturers share the same headlamp bulb, and GM has quad beams, I guess fogs are all the same?![]()
After dark, they all look the same...?![]()
just ordered my 35wt 5k lows and hi's and fogs 92.70 shipped, hopefully I get them before I get pulled over![]()
Did you get the Hi/Lo kit? My friend installed DDM's 9007 Hi/Lo kit on his '97 F250 the other day. It came with a controller for the low and high beams which fed the ballasts and seemed to draw it's power directly from the battery. That controller would make the relay harness redundant.have my relay kit installed, now more issues, going to call ddm tommorow, i think there is a fault in the original "module"....![]()
