Fluid Capacites!
Sweet! Thanks! :thumbs:
merlin5577
Taunton, MA
2007 Chevy Silverado 6.6l Duramax LMM
1999 Chevy Silverado K1500 350 5.7L - I am sure those will be the same capacities for the 98.
2007;
Engine, with filter..........10.0 quarts
Cooling System, Initial Fill..........25.0 quarts
Automatic Transmission, 1000 ReFill..........7.4 quarts
Automatic Transmission, Total Fill
6 speed 1000..........13.0 quarts
Differential, with 8.25 ring gear Front..........3.0 pints
Differential, with 9.25 ring gear Front..........3.7 pints
Differential, with 8.6 ring gear Rear..........4.2 pints
Differential, with 9.50 ring gear Rear..........5.5 pints
Transfer Case,MP1222/1225..........3.2 pints
Transfer Case,MP1226-NQG..........3.2 pints
Transfer Case,MP1625/1626NQF..........3.2 pints
Transfer Case,MP3023-NQH..........3.2 pints
Transfer Case,MVG261-NP2..........4.0 pints
1999;
Engine, with filter..........5.0 quarts
Cooling System, W/O AC Initial Fill..........17.0 quarts
Cooling System, with AC Initial Fill..........18.0 quarts
Automatic Transmission, 4L60-E ReFill..........5.0 quarts
Automatic Transmission, 4L80-E ReFill..........7.7 quarts
4 speed 4L80-E..........14.0 quarts
4 speed 4L60-E..........11.0 quarts
Differential, Front..........3.6 pints
Differential, with 10.5 ring gear EX Dana Rear..........6.3 pints
Differential, with 8.5, 8.6 ring gear Rear..........4.2 pints
Differential, with 9.5 ring gear Rear..........5.5 pints
Transfer Case,NV236/246..........4.0 pints
Transfer Case,BW1370/4401..........3.2 pints
Transfer Case,BW4470..........3.2 pints
Transfer Case,NP241/243..........4.4 pints
I was going to ask but thought he was just checkin for trucks..
I guess it wouldnt hurt...
2010 Chevy Equinox v6 3.0 DOHC VVT W/6speed tranny
Might as well put the dump truck in here...
1999 Chevy Silverado 3500HD 6.5L Turbo Diesel of which I am guessing 4L80E...
Sorry bud, I cant pull the information for 2010 models yet. When it becomes available I will post it.
1999;
Engine, with filter..........8.1 quarts
Cooling System, Initial Fill..........28.0 quarts
Manual Transmission, NV4500..........8.0 pints
Manual Transmission, NV3500..........4.2 pints
Differential, Front..........4.4 pints
Differential, with 10.5 ring gear Dana Rear..........5.5 pints
Differential, with 11 ring gear Rear..........8.4 pints
Differential, with 9.75 ring gear Rear..........5.5 pints
ryan_h
Sofa King We Todd Did
Renton, WA
1995.5 Toyota Tacoma 2.7L 4x4
Also 2008 Chevy Silverado 4.8L 4x4
2001 Suburban 2wd with 5.3 , 3.73 ring gears, w/aux trans cooler and rear AC
1997 Blazer 4.3 4x4 auto trans
2005 Altima 2.5s auto trans
dietz4ibanez
Willow Spring, NC
When is that 2010 Nox going to show up? I already found out that it takes 6 qts of oil!
