hotrodpc
- Joined
- Jun 28, 2009
- Posts
- 1,012
- Reaction score
- 1
yeah, tough to follow. An automatic will never go into gear with engine off. It won't do a thing cuz the front pump is not turning to pump pressure, so that is normal. With engine running if its not going into gear, then several things can be wrong. Like bad pump, direct clutch pack wore out etc. So hard to tell. But, this is not an electronic trans, so the shift indictor not working is not sign of anything other than the string that operatres it in the colum is probably broken. Trans needs a rebuild. PERIOD !!!!
