This posting is for a ford 2.3l turbo enigine, transmission and other parts the prices are gonna be far below the least exspensive listing you have seen of this quality so please dont bother trying to haggel me because i have no need to sell however i am reasonable and open for trades for 302 stuff must be in working order.
Ok this is what i have and what id like for it
1979 Ford 2.3 block and crank and rods crank has been turned .25mm on the rods and mains and has been assembled with matching clevite bearings.
The block is 30 over with forged trw pistons with perfect circle chrome moly rings .
The cylinder head is a stage 1 ported turbo head off of an 88 turbocoupe and is loaded with trw lifters and sealed power rocker arms and a comp cams turbo cam with new bearings and an esslinger billet aluminum adjustable cam gear i also have the esslinger tool and instructions. The head is held onto the block with a felpro 1035 head gasket and arp undercut head studs
The intake manifold is off an 84 thunderbird and has been machined to fit all the same sensors as the 88 turbocoupe (since i run an 88 turbocoupe harness and fuel system)
The fuel rail and injectors are off an 88 turbocoupe 36lb brown tops with a holley adjustable fuel pressure regulator attached
It also has a melling hphv oil pump, steel braded lines and a new wp, timing belt, timing belt tensioner, new auxilery shaft bearings, freeze plugs u name it. all painted no cruddy motor. capable of holding up to 500+hp as im selling it (The motor does have a stinger style turbo manifold on it that is cracked but can be fixed and a t3/t4 hybrid turbo with steel braided lines and a wastegate not sure if the wastegate is any good but the turbo worked on a buddies car but they come too)
all of this for 500 bucks with less than 5k miles on the all of the parts engines and it runs no low comp. no holes in the pistons. no blown head gasket. no blow by a strong 2.3l turbo could also be used as a high output na engine
I also have a firberglass 88 turbocouple stand alone wiring harness from the detail zone with an 88 turbocouple 5 speed large mass computer and the mass airflow sensor itself
all this for 250 bucks harness is 500 bucks itself shipped and is in brand new condition as its less then 6 months old as is the computer and mass airflow or vane airflow sensor if u wanna get technical
next on the list i have and 85 thunderbird turbocoupe t-5 with the cable bell housing in great condition no grinding
250 bucks takes it
I also have a complete stinger-performance front mount intercooler kit with everything needed to install it retails for 600
i will take 325
continuing i have a 3inch mandrel bent exhaust with a stainless steel downplipe already set up for the wastegate and fitted with an oxygen sensor bung and a wide band bung. exhaust is custom built with a flex joint on the exhaust and the wastegate provision to prevent cracking on both has a 3 inch offset to offset flowmaster muffler (no tailpipe)
will let it go for 150
like everybody else im sure im missing stuff but im in a particuarly generous mood so if someone wants everything in a bulk buy i will give them the deal of the century and let everything go for 1,100.00 and not a penny less
call or text 602-316-1009 if i dont answer leave a message or i wont call back thx
i can send more pictures by request
