Mixedbreed
Put a oil cleaner through it first. A sludge remover.
Apart from the poorly-designed stock EGR cooler, the 6.0 is not so bad as it's often pointed out.
False. The egr coolers were redesigned in 2005 into a square shape and Hence weaker. The 03-04 were round and much less prone to failure.
The heel of the 6.0 powerstroke is the 4 head bolts (torque to yield style) per cylinder compared to industry standard 6.
2nd heel is the huei injectoin system and supporting oil system. But that is a whole different beast.
When fitted with head studs, the head gasket issues all but disappear.
