davbell22602
Stihl Chainsaw Man
Pics no worky.
Fixed
Pics no worky.
Not kicking you in the nuts here, but I would find a different welder. Who ever welded that has no idea what he's doing.Not very good outcome in having the welder repair 4 rotted holes. He was only able to repair 3 out of 4 holes. Passenger side front cab mount frame wing needs replaced on frame. Welder used 11 gauge steel to weld plates under each hole. The 4th weld was just burning the wing even after turning the heat down on his welder. Someone here local told me to try Dessert Valley Auto Parts in AZ to see if they had a usable replacement wing.
That not finished. He stopped cause the heat is burning through the wing on the last pic. The rest were welded underneath and tacked on top.
