Tan Zuk
You will Love it or Hate it!!!
Finally decided on the next plan of attack.
Well, decided to try and put an empty block in for a trail install run. This was also done to mock up some brackets for AC and TG Toy power steering pump. The FJ80 box is close to where these components are going to live and wanted to make sure I had a real time look and see. Finally found a stock AC compressor with the manifold adaptors on it to use.
Getting the crane hoist in place and the engine block on the floor to see if a bottom side install could be done. Physics set in and there wasn’t enough ram length to get this done. The block was installed from the top with out problems even with the extreme height.
The trany will go in first. Don’t want to have to struggle with fitting it from underneath which is more of a PITA.
I’m also working on a removable trans mount. Ordered the Rock 4x mount to see how it looks. If used will probably modify it to eliminate pinch frame clamps and weld in a couple of angle pieces to the frame, this will make it a solid bolt in mount. May also add ¼ webbing around the outer sides of the mount this will add strengthen to the bent mount.
Here are a couple of pics of the block in for component clearances and bracket mock up. Engine bay hasn’t seen a block for about 2 years not really much of a big deal until you see the obstacles to over come to get it there.
