What PSI do you run?
mblouir
I need a hobby.
Greenville, SC
Title says it all. What are you running?
I have 33x12.5R20 Toyo M/Ts and am still adjusting the pressure trying to strike a good balance. Generally I keep the pressure high (within reason) to lengthen the life of the tires and increase economy. I don't notice any increase in ride stiffness so it doesn't bother me. I check it every few thousand miles to see how it's wearing.
Right now I'm testing out 50 psi up front and 45 psi in the rear.
B
Bernie
On the GMC I'm running 55 front and 65 in the rear, with 225/75R16 load range E
On the g/f's Dakota, with 235/75R15's we're running 35 front and anywhere from 35-42 rear, depending on how much load I stuff in the back.
I run 285/75/16 E rated Revos. I used to run them,unloaded, around 42 front 35 back. I noticed that the tires were starting to cup on the fronts. This was probably due to an oversized tire and not enough pressure. I increased it back to the manufacture specs(80psi) and they have started to run good again. Driving a HD, you try to get as much softness for a ride as you can.
