They are good for messing up your mass air flow sensor.. went through 3 of them![]()
You either bought a cheap one or installed it poorly. It should have no effect on your MAF
Its very easy to clean them. I had the same issue with mine. I was gonna do a write up on it at some point. Pull the cotton off the end of a q-tip so it is still attached but very loose. Then clean the sensor where the air flows over it. Works great.They are good for messing up your mass air flow sensor.. went through 3 of them![]()
Sorry... but it is physically impossible for a CAI to add low end torque. Any gain to be had would be at higher airflow levels.
