- Joined
- May 17, 2009
- Posts
- 57,295
- Reaction score
- 36
They really aren't that complicated or hard to do. I'm not sure what he's complaining about?
He's bitching about the room he has to work. He wants to wait until he has a day that he can spend all his time on mine. He's afraid of breaking something, and then not being able to get it today. Makes sense to me.![]()
Yeah, that makes sense.. You don't want him breakin' stuff!![]()
No offense Jeff but I'd look for somebody else. These aren't hard to do and I've never had any problem getting tools in or bolts out. I sure haven't ever had to heat anything with a torch.He's bitching about the room he has to work. He wants to wait until he has a day that he can spend all his time on mine. He's afraid of breaking something, and then not being able to get it today. Makes sense to me.![]()
He's also out of gas for his torches. He said he went to heat the bolts up, and poof. He can't get those filled until Monday.![]()
This is sounding a bit odd.![]()
I did discover a tip on the top torx bolt. You don't need to loosen it at all. You just take out the bottom one, lift it up and it slides out with a little wiggling.![]()
Well Dennis, as soon as I get it, I'll have to make a thread. This is another thing I'd like to do before installing the dash again. I'm assuming that a small section of harness (hopefully 1ft; or 30mm in your caseHoly shit!Ordered a new grill and put an offer in on an overhead console, both for the S10. If I get this overhead console, all I have to do is find another one in the junkyard to swipe the wiring harness off of and then figure out how to wire the damn thing.![]()
Enjoy
That's gonna take some serious thinking and reading.
Thanks Dennis!!!
I won the overhead console. "Buy It Now" price was $34 and I made an offer for $30 so I got the entire thing for $42. I probably overpaid for it, but it has the Mode button, HomeLink, and the headliner surrounding it is gray (matches my interior). I'm very happy with it. I guess I'll be taking a trip to the junkyard next week to search for another OHC equipped Blazer/S10.![]()
I'm gonna see how much I can find and get out of a vehicle. The only problem is that the main harness is hard to get out (from what I've read) with the dash in the vehicle (I think). Unfortunately, the Blazer I got my dash out of didn't have the OHC.
It looks harder than it is
I used some network cable for it
IIRC, you connect one wire to the ALDL wire, one to the VSS, and if you're browsing the junkyards, you need the temperature sensor that goes behind the grille.
As long as the OHC you bought has some of its wiring harness, you're good to go
All the Homelink needs is power.
I haven't done it yet, but I need to take my steps off because I sold them...
Go to Sears.....if Canada has them. They have a Torx set from T10-T55 or 60 from Lisle Tool along with all the sockets you need. I think I've got 1 or 2 22mm now (between the standard sockets and impact sockets).I did discover a tip on the top torx bolt. You don't need to loosen it at all. You just take out the bottom one, lift it up and it slides out with a little wiggling.![]()
Torx bolts are nice... But the bits are PITA to find sometimes.
I get to find a 22mm socket now... Gotta take my steps off![]()
Enjoy
Thanks Dennis!!!
I haven't done it yet, but I need to take my steps off because I sold them...) will be included like a pigtail. Without it, I'm gonna have to find that too.
I knew about needing the Ambient Temp Sensor. I'm guessing the VSS is the Vehicle Speed Sensor, but what/where is the ALDL?
With these 3 connections, will everything work (avg MPG, trip, compass, etc (I don't know all the features))?
I'll have to re-read this when I'm looking at the truck.Well Dennis, as soon as I get it, I'll have to make a thread. This is another thing I'd like to do before installing the dash again. I'm assuming that a small section of harness (hopefully 1ft; or 30mm in your caseHoly shit!Ordered a new grill and put an offer in on an overhead console, both for the S10. If I get this overhead console, all I have to do is find another one in the junkyard to swipe the wiring harness off of and then figure out how to wire the damn thing.![]()
Enjoy
Thanks Dennis!!!
The ALDL is the orange (If I remember correctly) wire in your OBDII connector.
The VSS is the speed sensor, and I tapped into it right by the cluster plug... Should be the green wire, 3rd from the left on the row closest to you.
The compass is 4 wires, and plugs in and stays on top the OHC, you should have an arm sticking off to the side for it to sit on... That goes over the head liner.
And 1ft = 30CM not MM![]()
