Well I'll Be Damned,Wifey's Burb Is Alive(How To,Kind Of)
Not bad huh Dave :D
Just took the Burb down the road to 7/11 for cigs..coming back I stepped on it a little and man did it take off,noticabley more power and acceleration.This is turning out to be a very good thing :thumbs:
Sweet Gary, :)
I guess new injectors and controller make a difference. Now to keep them clean. :)
OK,so whatcha got? :D Same stuff I put in my Burb or something else?
Just run fuel from a high turn over station, one that gets refueled often and every now and then a treatment of PI will help keep things clean from the valves back. :)
Were you able to look down the intake runners and look at the tops of the valves? If so how did they look?
Good to hear it's working fine. That bottom intake is the same damn plastic as the top, at least it was on my '99. :dunno:
dirtyoldman
Saugus,Ca.
Not bad huh Dave :D
Sweet Gary, :)
I burn Chevron in my Burb,I'll see if I can get her to burn it also.However she does use use gas from a high volume station so it's prolly always fresh.Never thought of looking down the runners :dunno:
Definitely aluminum on Linda's Burb,yours was plastic?go figure...:dunno:
Take a look at the secong to the last pic,you'll see it has a machined surface where the plenum bolts to.
The bottom should be aluminum which is also why there was such a problem with the intake manifold gaskets, being in contact with the iron heads and aluminum intake.
At least it's lighter than the marine intake! That's got an iron base and an aluminum upper. I've heard there is a HUGE difference.
dirtyoldman
Saugus,Ca.
The bottom should be aluminum which is also why there was such a problem with the intake manifold gaskets, being in contact with the iron heads and aluminum intake.At least it's lighter than the marine intake! That's got an iron base and an aluminum upper. I've heard there is a HUGE difference.
Hopefully that won't be a prob for a long time :thumbs:
dirtyoldman
Saugus,Ca.
Little Update...It's been a little over a month now and it's running great :thumbs: Haven't checked the mpg yet but wifey did say she is going longer before needing gas.Guess I did a good job of the repair :thumbs: She's been in a pretty good mood lately :D
Good to hear. So, I take it you're getting a little extra activity at home. :naughty:
dirtyoldman
Saugus,Ca.
I wish :lol: She did say she came into the bedroom a day or so ago with it on her mind but I was taking a nap,dammit :eek: :lol: Guess I was snoring so she didn't want to wake me up :(
:facepalm: That sounds all to familiar. :lol:
dirtyoldman
Saugus,Ca.
Must be an Old Fart thing :dunno: :lol:
motive
