Spark Plug question for Ford F-150 4.6L
ford4wd08
clarksville/knoxville, TN
Your are in luck. I changed my on the same engine two months ago. Stick with motorcraft, they aren't that expensive and they're good plugs. If you have a misfire make sure it isn't a coil as well. I had one COP go bad on cylinder 5 at 145000 miles, but it was a very easy fix. The plugs really arent that bad to change on this engine. Took about a hour and a half. You have to get a little creative sometimes, but as long as you have a few different sizes of extensions and a u joint you'll be fine. Just get a step ladder, if they're hard to get to on mine, I can't imagine yours!
Darth Bama
Zombie Control Specialist
Ga.
Re: Spark Plugs
Stay with the Motorcraft plugs, trust me.
Ramona CA
Stay with Motorcraft I picked all 8 up at auto zone for $12. I had them changed out in less than an hour. Just pull the fuel rails and you have direct access to all of the plugs and COPs. The back two plugs, I think were the only ones that needed a swivel socket but that was it.
Also Torque them down to 28Ft lbs and put dielectric grease in the cop boots
ProZach
Its a fucTMCTMCTMCTMC BRONCO! not a Jeep!
Chandler
motorcraft for sure.
the 5.4 tritons were the only ones listed on the TSBs for plugs breaking IIRC
ford4wd08
You don't have to remove fuel rails..... I didn't, didn't think it was necessary, just another opportunity for me to screw something up lol
Ramona CA
It will make the process a lot easier it two bolts per rail, then they just pop off. There is really nothing you can screw up. :)
bigredstx
If they don't scrub, they're not big enough
Spark plugs done! Didn't move the rails just used a lot of extensions, holy fWonk is was tight though. My whole body hurts from climbing over in it so high off the ground
ford4wd08
Haha I felt the exact same way. Glad to hear you got it done!
bigredstx
The old plugs were completely fried, nearly double the gap. The truck is running better than it has on a while, and my OD mis fires have disappeared :)
