surfcityZ71
- Joined
- Jan 28, 2014
- Posts
- 3
- Reaction score
- 0
That one looks similar to the one in my 2006.
http://i722.photobucket.com/albums/.../Front diff teardown/Frontdiffteardown060.jpg
Something that baffles me is why, after installing the two washers and the ring clip, there appears to be a tremendous amount of end play in the shaft. Is that end play controlled by the limited distance between the differential and the steering knuckle so that it becomes a non-factor? As you can see in your pic, that ring clip does little more than prevent the axle from sliding out of the housing.
