For me, no. The purge valve is in a tight placed on a bracket between the bed and the cab of the truck. The only thing that came off relatively easy was the wiring harness. The hose has an immediate 90 degree angle on it and my quick connect on this hose was too brittle to come off easily. I could unbolt the braket from the truck frame but couldn't slide the bracket off - again brittle plastic. All of this is complicated by the fact that you're working at an arms length with no leverage and most of the time, if you can get your hand on it you can't see what you're doing, and vice versa, with very little room to manuever any parts. For me, removing the bolts from the truck bed afforded me just enough room to maneuver. Still, in the end, I got so disgusted with the hose, that I just cut it so I could get the part out and it was only then that I could see exactly what the part looked like.
Spray some penetrating oil on the bolts a couple days before you plan to remove the bed. The 4 bolts on the front are easy to get too. The four on the back are somewhat hidden and you'll need a socket extension to reach through the framing to get to them.
DON'T FORGET: to remove your wiring harness for the tail lights (under the rear bumper just to the driver side of center)
AND: loosen your gas tank neck ( right at the gas cap). two torx screws and one of those plastic snap in "bolts"
AND: remove your gas tank ground from the frame (small wire runs from the gas tank neck to the bracket that the front bolt of the bed is attached to).
If you can get a couple guys to help you completely lift the bed off, I'm sure this would simplify the whole process, and leave time for pizza and beer when the job is done.
Good luck, NOLIFE1980
