63chevystepside
High speed low drag.
My gauge is manual aftermarket and its a stock oil pump-i just had thought if my oil pressure was running twice what it needed to be-fully warmed up(200 degrees)its pushing 70lbs at 60mph/3000rpm-that it would hurt the bearings/dist gear...im pretty sure the gauge is good to...at idle fully warmed up its 40lbs-before without the lucus add-it was 10lbs less with 20w-50. I just don't wanna screw anything up-im just really getting the thing darn near driveable/dependable. Most sites iv come across say 10lbs per 1000 rpm and if thats true at 60/3000rpm its 70lbs---what should i do? Some of the guys have mentioned to go to a 10w-30 an not to put the lucus add in-so i was going that way.
. Well i called a diffrent parts store an they got the zinc additve i can add to my oil-i was thinking castrol 10w-30 with the zinc...Iv got so much oil pressure it leaks a little off the side of intake and seems to blow alittle out vavle cover.
