New BFG KM2's (pics)
Those look good Wayne!
How are they in snow?
Mind if I ask how much per tire?
NMRam
Ft Sumner, NM
I haven't had them in snow, they are rated good on both TireRack and Discount. I doubt they will be great on ice though, there isn't a lot of siping in the tread.
The tires listed for $220 apiece (Discount Tire) + mounting/balancing/etc. I traded my stock tires with 3k miles and haggled some with the manager and ended up getting the set for $796 mounted/balanced/out the door.
matt3
I am lazy IS my custom title!!!
Illinois
Looks good!
Mind if I ask, why so narrow?
NMRam
Ft Sumner, NM
With the snow and heavy clay mud we have around here, a narrow tire that cuts through and "hits bottom" tends to have more traction than a wide tire which floats on top of the slick stuff. The narrower tires also allow me to run a little taller tire on the stock rims without rubbing on the control arms like some of the wider ones do. I actually have clearance in the fender wells to run an even taller tire, but if I went much wider, I would rub at full lock.
Darth Bama
Zombie Control Specialist
Ga.
Man, those look killer on there man! Very cool.
matt3
Illinois
Gotcha. Did you notice any performance decrease from the taller rubber?
