My new 84 Chevy K10
If my memory serves me right, those trucks had no relay for the headlamps. The current was all pulled through the headlight switch. I would rewire them with a new switch, and with two relays. One relay for the low beams and a separate relay for the high beams. You mentioned wanting to add winch lights and rear facing lights, go ahead and wire up an aux fuse panel with fuses and relays for each light circuit.
camarokid
painless wiring had/has a complete wiring harness for 73-87 C/Ks for $575 if you'd rather put a whole new harness in. and if your headlights aren't working I'd look at the switch in the dash or the grounds for the headlights.
transportjock
Albuquerque, NM
Ah thanks for that. I have been looking for relays without much luck. And I was thinking of swapping out to H4 lights up front from LMC (Custom Headlights - Dual Headlight Models | 1981-87 Chevrolet Pickup Truck 1981-87 GMC Pickup Truck | LMC Truck) and buying their harness that comes prewired... I'm a little lazy about wiring like that. And an aux panel is definitely in the works. The extra lights and winch are a ways off though, so I have some time.
transportjock
Albuquerque, NM
I'll check grounds. I swapped the connector from the old switch to a new one and they still didn't work. But I might just do the new harness thing eventually.
transportjock
Albuquerque, NM
Finally got around to taking some more pictures before I went to work
Interior from Driver side
The rats nest of a wiring I have under the dash
Well... my head lights don't work, I wonder why? New switch didn't work either
American Racing wheels all around
Manual hubs up front
Head on view
Passenger side interior
Headache rack I'm gonna be taking off shortly
And the back. No tailgate yet
454 under the hood
