My new 84 Chevy K10
dirtyoldman
Saugus,Ca.
Man that's gonna be a fun build :thumbs:
Noticed on your spreadsheet you had Cerullo seats,consider the new seat upholstery from LMC,I used it on a '77 GMC I had and it worked great.The seat currently resides in my son's '69 Chevy.
Want a little more performance from that 454?Advance the timing 4* more or so,I have my current 454 set at that.On my old '77 I had it advanced 6* more.
transportjock
Albuquerque, NM
I looked for that in the menu on LMC and didn't see it. I'll look around a little bit :)
And thanks for the tips! That engine needs a tune bad, and I'll definitely try advancing the timing.
The more I think about it the more I'm tempted to swap the Quadrajet over to a TBI setup from a newer 454
dirtyoldman
Saugus,Ca.
I used 38-2290LL
Truck Parts and Truck Accessories.
I was having trouble with my 454 too,carb was all messed up so I bought a new Edelbrock Q'Jet from Summit,worked great :thumbs:
Keep the carb,much easier to work on.
transportjock
Albuquerque, NM
I used 38-2290LL
Thanks for the link! And lol if I had the money for a new carb I'd be happy. I'll try rebuilding this one and go from there.
dirtyoldman
Saugus,Ca.
I used 38-2290LL
Good Luck on that,hope you have better luck than I did :D
transportjock
Albuquerque, NM
I used 38-2290LL
Lol I hope I have better luck than when I rebuilt my old CB500's carbs...
dirtyoldman
Saugus,Ca.
Those carbs should be a piece of cake compared to that Q-Jet.Isn't the hardest part synching them?:dunno:
transportjock
Albuquerque, NM
Pretty much. And it was a four cylinder so that made it even more fun. And that was the hardest part. I'm gonna get a new air filter and try to mess with the idle mixture screws and see if that will help me a little at least for now
Sent from my SPH-L720T using Tapatalk
dirtyoldman
Saugus,Ca.
I was having idle issues with both my xr350 & xr600 so I removed the idle mixture screws on both,shot some brake cleaner in the hole and blasted each with a shot of air.Then replaced the screws,bottomed 'em lightly then backed 'em out 1 3/4 turns IIRC.Once running I played with the screws a little more and got both xrs idling pretty well.
Might be a little dirt in the orifice,just cleaning might help.
