LY6 engine
Yes. If it is an upstream(before cat) sensor. The sensor is not telling the ECM if it needs to pull or add fuel.
AaronG1981
Manor Sk Canada
well its not the 02 unplugged em it really ran like shit lol plug wires done and new air filter next is a good injector clean
ok 2 of the thing my scan says r 02 bank 4 sensor 2-3 as far as i know there is only 4 senors and 2 banks
That program you use has some crazy way to say the simplest thing.
Correct there are 2 banks and 2 sensors per bank. I have never seen a bank 4. I should be bank 1 or 2 sensor 1 or 2.
AaronG1981
Manor Sk Canada
this is what i got from my app im hoping some 1 can point me in some directions on what is ok and what needs some new bling lol
thanks Aaron
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0.45018V Min: 0.45018V
Test result value: 0.45018V
PASS
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
PASS
MID:$01 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.30012V Min: 0.30012V
Test result value: 0.30012V
PASS
MID:$01 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.60036V Min: 0.60036V
Test result value: 0.60036V
PASS
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 189ms Min: 0ms
Test result value: 29ms
PASS
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 127ms Min: 0ms
Test result value: 24ms
PASS
MID:$01 TID:$80
Max: 61,443Changes Min: 50Changes
Test result value: 212Changes
PASS
MID:$02 TID:$8a
- O2 Bank 1 Sensor 2
Max: 1,450Count Min: 0Count
Test result value: 703Count
PASS
MID:$02 TID:$8b
Max: 1.10068V Min: 0.73041V
Test result value: 0.77177V
PASS
MID:$02 TID:$8c
Max: 0.22509V Min: 0V
Test result value: 0.01745V
PASS
MID:$05 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 2 Sensor 1
PASS
MID:$06 TID:$8a
- O2 Bank 2 Sensor 2
Test result value: 275Count
PASS
MID:$06 TID:$8b
Test result value: 0.76006V
PASS
MID:$06 TID:$8c
Test result value: 0.04331V
PASS
MID:$21 TID:$a0
- Catalyst Monitor Bank 1
Max: 0.99939 Min: 0.29981
Test result value: 0.99482
PASS
MID:$22 TID:$a0
- Catalyst Monitor Bank 2
Test result value: 0.99375
PASS
MID:$3a TID:$c0
- EVAP Monitor (cap off)
Max: 14L Min: 0L
Test result value: 1.458L
PASS
MID:$3a TID:$c1
Test incomplete or dependant test failed
MID:$3c TID:$c8
- EVAP Monitor (0.040")
MID:$3c TID:$c9
MID:$3c TID:$ca
MID:$3c TID:$cb
MID:$3d TID:$c4
- EVAP Monitor (0.020")
Max: 6,553.5S Min: 60S
Test result value: 60S
PASS
MID:$3d TID:$c5
Max: 2,500Pa Min: -8,000Pa
Test result value: 75.5Pa
PASS
MID:$3d TID:$c6
Max: 60S Min: 0S
Test result value: 0S
PASS
MID:$3d TID:$c7
Max: 40L Min: 10L
Test result value: 10.019L
PASS
MID:$41 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 8Count Min: 0Count
Test result value: 0Count
PASS
MID:$41 TID:$d3
Max: 2.481 Min: -4.211
Test result value: -0.177
PASS
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$42 TID:$d3
Max: 3.86 Min: -6.83
Test result value: -0.894
PASS
MID:$45 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 1
PASS
MID:$45 TID:$d3
Test result value: -0.369
PASS
MID:$46 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 2
PASS
MID:$46 TID:$d3
Test result value: -0.439
PASS
MID:$61 TID:$76
- Heated Catalyst Monitor Bank 1
Max: 1.24995inch Min: 0.81789inch
Test result value: 0.40504inch
FAIL
MID:$91 TID:$33
Max: 1 Min: 4,177
Test result value: 13,200
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 1Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
Test result value: 4Count
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
Test result value: 13Count
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Test result value: 6Count
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 42Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
Test result value: 20Count
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
Test result value: 12Count
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
MID:$a8 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data
PASS
MID:$a8 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data
Test result value: 3Count
PASS
MID:$a9 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data
Test result value: 2Count
PASS
MID:$a9 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data
PASS
MID:$e8 TID:$30
Manufacturer defined MID -
Max: 409.60001 Min: 5,641.7002
Test result value: 2,893.1001
FAIL
End of report.
MID:$e8 TID:$30
FAIL
I have no clue what this is.
MID:$61 TID:$76
FAIL
This perplexes me as the sensor passed in another test. If i am understanding them correctly, the heater itself in the O2 passed, but you are getting a Catalyst efficiency code.
From what I gather the O2 is bad or you may possibly have a clogged cat.
The only other thing I can think of is to clean the throttle body.
