IH 54 R-100 4X4
Golly, this has been a chore !
Sourcing used parts to build the stand is going well ..
Tomorrow will be picking up some Flow Master mufflers ...
Changing gauges, found some AutoMeter's ..
Have you had this running? I see a tube in a gas can that looks like it's going towards the engine. :dunno:
Jesse S
Belleview Florida US of A
Not yet ..
Was testing out a used electric fuel pump .. Had it mounted to the stand .. Worked for about 20 seconds and it started to sing a Bob Dylan song ...
"Ain't going to work on Maggie's farm No-Mo"
Got a new cheapie ele. pump on the way ..
In the mode of getting the run stand on line ..
Decided to use the mechanical Auto Meter gauges instead of the boat's ele. ones ..
Might change out the tach to a better one too .. ??
The boat tach would serve the purpose, but might plug in a Sun Tach if I can run up on a cheapie .. ?
Being the run stand will see limited use, really don't want to spend a lot of green on it ..
Jesse S
Run stand is going together right nice it is ...
Moving the radiator back 10" gave enough room to mount the gas tank ..
Headers & control panel is in route ..
Along with the throttle control ..
motive
