Do you have the interior put together yet?
I like your set up for lying on your back to work under the dash...genius!That's next on the to do list ..
Must finish working the firewall, lots of holes to weld up ..
Will be seeing POR-15 on the inside, engine side will get epoxy primer and after sanding bed liner will be applied ...
All of the engine bay will have the bed liner ..
That's going to take some time to accomplish ..
After all of that is done and over will be spending more time laying on my back wiring under the dash ..
I thought you may like this. A 1942 Ford PU with a small block Chevy engine.
Yes, and with good reason. Before all of the LS swaps, the small block Chevy, was the most supported engine, by all of the aftermarket manufacturers. I have had many over the years, and love the 2,,, 350s I have now. Easy to work on, and fairly easy to make 400 plus HP, and even more.
