Ignition cylinder trouble for a 2000 Ranger.
Lonesome7.3
By whatever means necessary …
Columbus, GA
The truck will not even try to start. I tried placing the old key next to the new one and still a no go.
Lonesome7.3
Columbus, GA
it ran fine before swapping out the ignition, it would be my luck this is the time something else decides to fail.
Maybe you didn't get a good connection when you plugged it back in? I'd try the connections and check the clutch / neutral safety switch.
Lonesome7.3
Columbus, GA
On my next day off I will have to dig some more. I removed it and re-installed it again just to make sure and it appears to be installed correctly.
