so they called back with full prices for everything. are you sitting down.....god i hope so.
for the 4 brand new brake rotors, pads and calipers....plus the new hub bearings....they wanted $4k. umm, yea.....i'm not going to say anything else about that.
the steering problem, they are replacing a shaft....$250 parts and labor.
airbag seat position sensor.....$225
i only opted for the steering shaft bologna. not comfortable attempting that.
thanks for all the feed back. i'm going to check out that hub thread most definitely.
as i mentioned, found hubs for $85 each. is this a good price? found them on hubandbearingwarehouse.com comes w/ABS cable. thats all i need right?
a shop i took it to before the dealership said my rotors are plenty good. t he dealership says (and its true cause i can see it myself) that theres lots of rust on the rotor. if i have the rotor resurfaced (turned?) whatever they call it, will this solve the rust problem? or i'm going to just go with....
autotruck toys has some slotted rotors for $225. only the fronts, i never asked them to look at the rears. typical dealership, lets tell him he needs to change everything BS.
calipers......these they say are rusted up as well. what can i do to fix this problem? go aftermarket better performing? need more help with this then anything really.
thanks for the input as always. great group of guys on hear always trying to help out. appreciate it.
