mblouir
I need a hobby.
I was always under the other assumption. No one's ever said that from the Big 3 upgrades I've read. Thanks for pointing that out, Bernie! Looks like I need to purchase a new fuse.Glad to do it! It was fun for me and hopefully it makes this easier for others.
Two things were brought to my attention:
1. Wire Loom
2. Fuse Rating
I will be putting wire loom on all the wires---I was just running short today and it's been a long week. I wanted to put this up while I had the spare time.
I used a 250A fuse because KnuKonceptz rates their flex cable at "over 300A". Some people say match the ratings, some say you don't need a fuse, etc, etc. First of all I used a fuse to be safe. Even though power flows both ways I don't want the wire to get overloaded. I chose a 250A fuse because in the case something happens I want the fuse to blow before the cable reaches its limits. Just staying safe.
The main purpose of that fuse isn't to protect the cable, it's to protect the alternator. You want the fuse to be just slightly above the rating of the alternator so that if something starts making excessive demands on it the fuse will blow before the alternator fries.
For a stock 100 amp alternator I'd use a 125 amp fuse. On my 140 amp system I use a 150 amp breaker.
