NMRam
So I added the factory trailer brake controller in my 2010 Dodge Ram. It is basically plug and play on the 2010+ Rams.
This mod will not work on 2009 models. It was not a factory option for 09 and they don't have the dual plugs like the 2010+ models.
First I ordered the Trailer Brake Control Module and the trim Bezel. List price on these items was around $170, but the dealership I bought it from gave them to me "at cost" and the total was $121. Also, when I ordered, I asked for the trailer brake control module and was told that they did not sell that. I called back and just gave them the part numbers with no description, and they were able to order it no problem.
Part numbers:
Factory Brake Control Module - 56029431AE
Dark Gray Bezel - 1EB13XDVAA (different colors are different P/N's)
You will also need 3 trim screws (or I used 3 sheet metal screws I had)
To install, you must first take the kick panel under the steering wheel loose. There are two screws at the bottom, then the clips just pop loose when you pull (gently). Next, you must remove the side panel on the dash. It is just held in place with clips, I started the bottom and pryed it up and out.
Once you have these panels off, there are two torx screws that hold the little delete pocket into place, one in front and one on the side. The pocket then pops out. Next you can assemble the controller and bezel. The brake control module slides into the bezel from behind, then there are two screws that hold it in place, one on top and one on the side (I used short metal screws). Once it is together, slide it into place. The plugs for the control are taped up to the main harness under the column. Untape them and plug them in.
You can then start the vehicle and make sure everything works (the camera flash doesn't allow the display to show).
There is also one screw that goes into the side of the trailer brake control module through one of the dash brackets. Once you have that in, put the dash back together, and you now have the factory trailer brake control.
For vehicles that have the EVIC in the cluster (mine does not) you will not get the trailer brake information to show up in the display unless you have the dealership reflash the BCM to add the "XHCA" option with the WiTech tool. The display in the cluster will then show the trailer brake controller information (gain, trailer connected, faults, etc). This step is not really necessary as the display on the trailer brake control also shows this information, it is just an option if you want it to work EXACTLY like the one that is factory installed.
This post reflects my experiences in doing this mod, and I will not be held responsible if you try it and fail or ruin your new vehicle.
Enjoy!
Part numbers:
Enjoy!
