B
Bernie
I think I figured out the problem... or part of it. You're feeding the low beam ballasts from two different points when it should be just one. Instead of having relay #3 send power to the ballasts, have it send power to energize relay #1, which will then turn on the low beams.
You should be powering the low beam relay, not the low beams themselves... The relays are powering the lights
If you're already doing this... You definitely have some digging to do![]()
OK, so I need to get rid of the 3rd relay and have the low beam relay get the signal from 2 places: factory low beam and factory high beam.
If that sounds good, I'll run a wire.
No, because if you do that then you'll never be able to turn the high beams off as long as the low beams are on. Also, if you were to connect a wire from the output of the high beam relay to the trigger on the low beam relay that wouldn't work either. The signal turning on the low beams would also turn on the high beams by bypassing the relay. What would work is connecting a wire from the low beam relay trigger to the high beam relay output, but using a diode in there so that current can only flow one way (to energize the low beam relay but not energize the high beam ballast when the low beams get turned on).
I used to buy them in bulk when I was installing alarms and remote starters.
