What I bought:
TYC Elegante headlights
from StylinTrucks.com
DDM Tuning Apexcone
9006 35w 5k = lows
9005 55w 5k = highs
Optronics Thinline LED lights
from Advance Auto (here)
I scouted out where the ballasts will go.
The lows will be mounted on the inside of the fender (same as 700 Sportsman (Tyler) did; click here for pics - see post #4).
The highs will be mounted on the front of the radiator core support (only spot with room and that is close enough).
I've come up with an idea as to how to mount the LED lights, but I'm concentrating on the HIDs first. They are my priority right now.
Special thanks to Bernie for all his advice on how to wire everything up and using relays. (I've never done much automotive wiring, let alone using relays)
For more information on some of the stuff I had questions on, see my "Need Light Placement Input" thread.
PICS !!!
Neoprene pads I cut for between the ballasts and the body.
Neoprene for between the ballasts and brackets.
Brackets (made out of 3/4 in. galvanized pipe hanging material)
Passenger Side Low Beam Ballast
Driver Side Low Beam Ballast
Passenger Side High Beam Ballast
Driver Side High Beam Ballast
Relay Rack
Shot of the lows on
Here is my video I took really quick.
[YT]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/IfVFEw5hvWk&hl=en_US&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/IfVFEw5hvWk&hl=en_US&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/YT]
I'll get more pics of the wiring some other time. Might not be until the weekend.
DDM Tuning Apexcone
9006 35w 5k = lows
9005 55w 5k = highs
PICS !!!
Relay Rack
Shot of the lows on
