Good Place to get an oil change ..
Discussion in 'Lubrication & Maintenance' started by miramballer, May 28, 2009.
  1. nobrakes00
    nobrakes00 I can speak Russian in French!
    Orange County, CA
    i do mine myself, but jiffylube or ezlube would probably be okay. they usually always send out coupons in the mail, and unlike most dealerships where they take your vehicle out of sight, at one of these drive-thru lube places, you can watch them perform the work.
    again, i'm a big advocate of diy cause i know it will get done right, but the places mentioned do millions of oil changes and should be suitable if you're not willing to diy.
  2. miramballer
    miramballer I'm NEW... What now?
    Kenner, LA
    Basically, I was under the truck today, I'm a big guy, I dont have lifts or anything to put the truck on so I barely fit under there .. I saw where the oil filter was and where the nut to drain was .. I cant really get under there though .. a friend at work said He'd do it for 10 bucks . . Probably will just go that route
  3. Bigredmariner
    Bigredmariner Administrator
    I normally do it myself, only if I'm extremely pressed for time do I let someone else do it.
  4. daddy
    daddy Administrator
    Damn, Haas. :eek:
    How frikkin' big are ya? I'm 6'4" and 220 and I can slide right under.
  5. nobrakes00
    Orange County, CA
    go to autozone or one of your local autopart's stores and buy a Rhino Ramp. Two different weight limits; one can hold up to 8000lbs. and the other can hold up to 12,000lbs. they are $35 and $45 respectively.
  6. OldCracker29
    I also change my own. It's just something I don't mind doing. In fact, I rather enjoy doing it. Plus it gives me satisfaction of knowing it was done right, and with the oil of my choice. :thumbs:
  7. takevin
    takevin I'm special! I'm so pretty to be me!
    burbs of IL near WI
    ][​IMG]
    I go thru barrel loads:thumbs::D
  8. Bigredmariner
    Need to paint that barrel orange. :rollin:
  9. RebelThunder
    RebelThunder Speak English or GTFO
    A Tree Stand
    What happened at the dealership?
    I've usually get mine changed there because I have free oil changes.
  10. takevin
    burbs of IL near WI
    [​IMG]ok:lol::thumbs:
