GM torsion bars
NMRam
Ft Sumner, NM
They really should use the GM torsion bar removal tool.
http://store.4wheelingplus.com/proddetail.asp?prod=1069&partner=froogle
All that does is unloads/loads the keys, it won't help get the bar out of the socket.
It also aids in reinstallation, but I see what you mean.
R
Riggs
what i do if the key is stuck in the torsion bar is stick a 1/4" plate between the front of the crossmember and the key and then use my mac air hammer or 2 lb sledge with a big bolt in a vice grips to pound on it,
if it is stuck in the lower control arm and free from the key, then i have a old torsion bar i cut in half, and stick a 1/4" plate between the backside of the crossmember and the key, and pound on it with a big sledge hammer from the front of the truck.
and today i had to do a leveling kit on a 2008 GMC Sierra 2500, and typically the passenger side is always the hardest side to get out since the exhaust is there and rusts the key, torsion bar quicker, but i had to use a torch and heat the the bar/key in the access hole in the back and get it cherry red, your not trying to cut it... and it fell right out afterward
R
Riggs
also another tip when you get them is out coat both ends of the torsion bar hexs with anti-seize as well as the adjuster bolts, because if you ever have to mess with them again they will fall right out and it wont be a pain in the ass next time around
