Gave My Tranny A Treat Today (pic Heavy)
dirtyoldman
Saugus,Ca.
Thanks for the pic :thumbs: Not sure if I'd put the sending unit in the drain plug hole,I go off-roading on occasion and it might get caught on something but it appears that the hole can be almost anywhere.
Wyley87
Granbury, Tx
Yup it seems to be just as thick as the OEM pan I took off. If not using the drain plug hole you could just get a pipe collar, drill a hole in the side or something and weld it in.
Sent from Texas
dirtyoldman
Saugus,Ca.
Sent from Texas
Yup,that's what I was thinking,I have a friend with a welder :thumbs:
Wyley87
Granbury, Tx
Sent from Texas
Sounds like a plan. :)
Sent from Texas
When I flushed mine I replaced all the fluid with Dexron 6. Its a far superior fluid to Dexron 3, and its backwards compatible meaning it can replace Dexron 3. All the oil companies have even stopped making Dexron 3, they only make Dexron 6 now. As I'm sure you might have seen when shopping for your fluid, you can only get Dexron 3 in the parts store brands now since companies like Mobil and Castrol only make 6 now.
When I fist put the Dexron 6 in mine, I noticed that it shifted slightly better. But the biggest benefit I noticed was that from then on, my transmission temps were always 5-10 degrees cooler than it was before I replaced all the fluid.
Good job Gary! Messes come with the job some times. :lol: That old fluid looked in great shape. How many miles were on it?
Inside that pan didn't look bad at all Gary. I'm sure the fluid swap will extend the life of the trans.
mr_bots
Fort Kickass
:thumbs: Trannies always like treats
I doubt the same pan that fit Louis's would fit yours. Half tons have 4L60s while the 3/4 tons have 4L80s. They probably make one though that'll fit the bigger tranny.
Jeff Dodson
