What are the CA(Cranking Amps) on the battery? You want something around 800 amps and above.
Most alternators put out at least 13.5-13.8 volts when running. Some put out as much as 14.5 volts. But regardless, 13.25 should be enough (I'd think) to charge your battery.![]()
I'd go to another parts store and have it checked again, see what they say.
Autozone said that it should be 14.5 on the charging system.
13.25 is pretty low. It should work, why the truck still runs, but not enought to keep the battery at is fullest potential.Most alternators put out at least 13.5-13.8 volts when running. Some put out as much as 14.5 volts. But regardless, 13.25 should be enough (I'd think) to charge your battery.![]()
I just bought an Autocraft Gold about 6 months ago from Advance Auto Parts. It was just under 100 bucks with tax and everything. 3 years free replacement warranty and 84 month pro-rated warranty.
Dave, what's the voltage at the battery immediately after starting the truck? (You'll need someone to start it while you check the voltage)
I'm betting you'll see a voltage of around 14 to 14.5, dropping down to 13.5 (approx) as the alternator quickly replaces what was drained from the battery while cranking. If that's the case then the alternator is good.
(Oh, and it'll probably drop to 10 or so while cranking, then climb up to 14.5 and then taper off)
