We don't have any Costco stores here.
Dave, what's the voltage at the battery immediately after starting the truck? (You'll need someone to start it while you check the voltage)
I'm betting you'll see a voltage of around 14 to 14.5, dropping down to 13.5 (approx) as the alternator quickly replaces what was drained from the battery while cranking. If that's the case then the alternator is good.
(Oh, and it'll probably drop to 10 or so while cranking, then climb up to 14.5 and then taper off)
12.50 then drops to 10.15 then goes up to 12.50-13.15. This is on hot/warm engine start.
We don't have any Costco stores here.![]()
