Dome Override Switch Light Question
That last pic is a socket I believe. Turn it with a flat blade screwdriver to the left gently and the bulb and housing should come out.
THIS You can actually remove that bulb without taking the switch apart. Turn it a quarter turn and pop it out. The bulb leads run thru two holes in that plastic socket and they wrap around the end of the socket where it touches the circuit board.
Oh ok, I got that, I guess the pics had me a little misled. I thought he was thinking the actual pushbutton was lit. My mistake, carry on..:uhoh:
The push button does not light up. Neither does the icon above the dimmer wheel. Just the icons around the headlight switch , and the "Dome Override" words are just barely lit.
Just out some stickers where the lights used to be to keep the theme going. :jester:
