Cluster change.
Correct Dan, I just did an overlay. All the original stepper motors were re-used. It was a kit with the overlay and needles. I wasn't concerned then with having the trans temp.
OPGMC
There are several people on Ebay that sell the clusters and will program them for you as part of a purchase. I personally haven't purchased one but some guys on here have. Hopefully they will answer up and correct me if I have it wrong.
IIRC you did a cluster swap right Jrod? What did you do?
I think he just replaced the gauge faces.
Ah, is it a hassle to have it programmed at the dealer?
What would you guys do?
Buy one and have it programmed from someone on eBay OR buy one unprogrammed and take it to the dealer
If I had it all to do over... I would just by a factory cluster in the style you're after, have the seller program mileage. Then install it and if the trans temp doesn't work have the dealer "turn" it on for you. My $0.02.
DV2000NJ
The Browmaster
Central NJ
I bought one unprogrammed, and am planning on taking it to the dealer.
What cluster swap did you do dan
I went with the Denali cluster. Other than the trans temp, it's a lot like stock, just a few subtle things that make it look better.
DV2000NJ
The Browmaster
Central NJ
Goes up to 120. Though, I don't know why you'd want to go over 100. Once was more than enough for me in the truck.
Jeff Dodson
